Hillbillydelux 69 Ranger
- basketcase0302
Re: Hillbillydelux 69 Ranger
HillBillyDelux,
I did find a couple of different throttle linkages here. And yesterday also found that my 79' dent gas pedal assembly is actually about one inch longer/taller in the engine compartment side. Here's a couple of pictures of the linkages that might help you. Both of the below measure about 10 and 1/2" long.
The homeade "extended" linkage from my 79' with a 302:
http://s240.photobucket.com/albums/ff13 ... g&newest=1
The 79' dentside offset linkage:
And a 460 cable linkage type intake manifold bracket:
I hope to use my dent pedal assembly, and find the cable and intake mount for my 302, (seems like I had one/can't seems to find it).
IMO the cable type is a lot more forgiving than mechanical type linkage. Especially if you have worn cab bushings like I do.
- HillbillyDelux
i took off the 1" carb spacer which allowed me to adjust my current linkage so i can now achieve both idle and WOT it runs a lot better and seems to have a tad better low end than with the spacer. It runs a lot better with the new intake and exhaust!! if i didnt know any better id think it was fast haha I think it still needs jetted down a tad tho
2000 Ford Ranger 4x4 "DD"
2003 Cobra
"If it ain't broke fix it til it is"
2003 Cobra
- HillbillyDelux
wont be long and Blueblue will be in the lowered thread!! i already did the half hanger flip on the back now i gotta cut some front coils!!
2003 Cobra
2003 Cobra
- HillbillyDelux
The plan its a photoshopped copy of the before
before
after
i think its pretty close to the plan even got the tips but u cant see em cuz the engine was runnin and its very cold out
edit: and i jus noticed my tag light isnt burnin so ill have to check my connections on it
before
after
Last edited by HillbillyDelux on Fri Jan 08, 2010 7:07 pm, edited 1 time in total.
2003 Cobra
2003 Cobra
- HillbillyDelux
another for good measure. you can see the tips a little bit in this one
2003 Cobra
2003 Cobra
- HillbillyDelux
ok just one more its a fuzzy cell phone pic but it shows the stance pretty well.
i think im going to take another half a ring outta the front coils to get the nose down a bit more
2003 Cobra
2003 Cobra
- 1967AceStroker
Looks good, makes me want to drop mine just a bit. How hard was that to do?
- HillbillyDelux
the front was a breeze but it was fairly difficult to get the rivets out of the rear. they grind down pretty easily but they're hard to knock out so you can get the bracket loose
2003 Cobra
2003 Cobra
Looking good. Keep the pics coming.
- HillbillyDelux
thanks. ill take some more and post em up as soon as i get it cleaned up. might even throw in a burnout video
2003 Cobra
2003 Cobra
- HillbillyDelux
my buddy cut this one short but u get the idea
http://s889.photobucket.com/albums/ac99 ... 0_3272.flv
X-PIPE!!!
http://s889.photobucket.com/albums/ac99 ... 0_3271.flv
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.sw ... 0_3271.flv">[/video]
X-PIPE!!!
2003 Cobra
2003 Cobra
You cant beat the X pipe sound.
- HillbillyDelux
you speak the truth. I love it
2003 Cobra
2003 Cobra
- HillbillyDelux
there are some more vids on my photobucket as well...open headers idle and rev, new exhaust idle and rev, and a couple in cab with open headers u gotta turn up the sound to really appreciate them haha
2003 Cobra
2003 Cobra
- Caseys71
, The X-pipe sounds wonderful , and I watched a few of your other videos, well listened to them .
Casey
