72 crew (update)
- zakt
72 crew (update)
Well got the rear seat out and the gas tank with associated hardware out and pulling the window tonight 1/20 (wednesday)... now can get to the body mount bolts and ready to pull the cab off. Bought (4) 1500lb a piece wheels off ebay for like $40 so making a roll around dolly deal for the cab. Finally also found a 18 1/2 C6 out put shaft (standard is 15 1/2, easier to find)to use my long adapter with the married NP205 ... Trying to get the driveline possibly long enough to get rid of the carrier bearing but have to see what the measurements are..
1972 Ford F350 crewcab
- 1971ford
Re: 72 crew (update)
Nice!
You should make an official update thread, so all your previous updates would be in the same thread
-Ryan
Hey Todd,Good to hear the project is "rolling along" Keep up the progress and post pics!
anything worth doing is worth doing in EXCESS!! - Carroll Shelby
70 F-350 4X4 crew
70 F-350 4X4 crew
- zakt
not to much happening now except tear down, once the assembly and changing happens will put that all in one thread
Rob,
on the back side of the rear door on your crew, about half way up were the metal joins is your truck dented in there?? Looks like both sides of mine are dented and not lined up the greatest. I will get a pic later tonight after work and get a pic below.
Todd
Rob,
Todd
