The theme of the truck is to keep it a late 60's very mild custom. Modifing things most guys wont know are changed unless you are familiar with these trucks.
All side and lower chrome has been removed and holes welded. The only chrome I am keeping is the roof drip rail and roof bet line chrome.
It will be artic white with a red metal flaked roof and mooneyes red metal flaked steering wheel. The rear has been flipped and the helper spring removed. The front coils have been cut and it still needs an alignment. Rims are Wheel Vintiques series 64 with pinner white walls. The seat is white with red piping and a gray center section that has been pleated. Carpet will be red as well as the seat belts.
All the seams have been welded up and smoothed on the truck as well. Hope to have it on the road mid spring if all goes well.
Thanks
Larry
