'68 engine swap has begun
Brokenarrow
Post by Brokenarrow »
Well deer season is over so it's time to work on the 'ol ford. Finally yanked the 6-banger/3spd and got the FE/C6 setting in it's place. It's been 15 years since I built an engine, hope I got it right :pray:
'68 SWB f100, 401ci FE/C6, '68 Mustang fastback (restoration in progress)
2013 F150 KingRanch (ecoboost), '48 8N tractor
"Be more concerned with your character than your reputation, because your character is what you really are, while your reputation is merely what others think you are."
— John Wooden
knightfire83
Re: '68 engine swap has begun
Post by knightfire83 »
Looks good! :thup:
See ya got a Quadrajet carb on there..... :wink:
1974 Ford F-100 4x4- 360 / manual.
1970 Ford F250 4x4 ~ Sold.
Brokenarrow
knightfire83 wrote:Looks good! :thup:
Thanks, yea the carb is from a '73 Buick. This is the 4th FE I've had with a Qjet on it. Fords luv'em :D
— John Wooden
tybob81
Post by tybob81 »
Looking good. Never heard of anyone putting Q-jet on a ford before.
Caseys71
Post by Caseys71 »
That FE looks right at home between those frame rails :D. Your project's looking pretty good :thup:, Deer season may be over, But what are you going to tow the duck boat with? Duck season is a booming here in NC 8). Also I was JW what kind of advantages do you see out of a Quadra-Jet versus an Autolite 4bbl?
Casey
BobbyFord
Post by BobbyFord »
Caseys71 wrote:...Also I was JW what kind of advantages do you see out of a Quadra-Jet versus an Autolite 4bbl?
Small gas saving primaries and king-sized gas guzzling secondaries. Ford had a Motorcraft spreadbore similar in design on 429's in the 70's.
Brokenarrow
Caseys71 wrote:That FE looks right at home between those frame rails :D. Your project's looking pretty good :thup:, Deer season may be over, But what are you going to tow the duck boat with? Duck season is a booming here in NC 8). Also I was JW what kind of advantages do you see out of a Quadra-Jet versus an Autolite 4bbl?
Oh I've got another truck, an '06 Chevy. I just keep the Ford around to drag it home when it breaks down. :wink: IMHO the autolite 4100 is THE most dependable carburator ever designed, and I do have a few of'em layin' around BTW. But in my experience you can get better mpg AND performance, hands down, with a well tuned Q-jet than any other carb. :2cents:
— John Wooden
basketcase0302
Post by basketcase0302 »
I'm about to go through the same thing... :roll:
It oughta' breathe good with the quadrapuke I mean quadrajet and those headers! :thup:
Caseys71
Post by Caseys71 »
:lol:, I've heard about the gas mileage part but I figured the performance would be about the same, at least that was the talk around town when I first got my :eek: No*a, but I sold it to get the bump :P.
10-4
Casey
Brokenarrow
A Q-jet that's capable of 850cfm will run great on an engine that only "needs" say 600cfm IF it's tuned correctly for that engine. (Try that with a Holley :eek: ) That's the beauty of the design, they are very tunable. If I didn't have tinkeritis I'd definitely go with a 4100 though :)
— John Wooden
