old school 68 long bed Ranger
Here are some photos of my 68 long bed Ranger. It is a 360 with 3 on the tree and a/c truck.
The theme of the truck is to keep it a late 60's very mild custom. Modifing things most guys wont know are changed unless you are familiar with these trucks.
All side and lower chrome has been removed and holes welded. The only chrome I am keeping is the roof drip rail and roof bet line chrome.
It will be artic white with a red metal flaked roof and mooneyes red metal flaked steering wheel. The rear has been flipped and the helper spring removed. The front coils have been cut and it still needs an alignment. Rims are Wheel Vintiques series 64 with pinner white walls. The seat is white with red piping and a gray center section that has been pleated. Carpet will be red as well as the seat belts.
All the seams have been welded up and smoothed on the truck as well. Hope to have it on the road mid spring if all goes well.
Shows some of the pre-primer body work
Shows the hood seams filled and dash treatment
Shows dash treatment
Bedsides
Tailgate treatment
Thanks
Larry
Bedsides
Tailgate treatment
Thanks
Larry
- marz68
Re: old school 68 long bed Ranger
I cant wait to see the paintmarz68 wrote:Nice! I like!!
1970 F250 Camper Special
- 67nukeford
Very nice, keep the pics coming!
So I got it in primer and reassembled to make sure all the panels line up right......now starts the wet sanding!
- 67mann
and the truck is looking goodQC wrote:I wish I had your shop!
I wish I had the shop and the truck! looking real good
1967 Ford F-100 Shortbed 390 V8
- jveenker
the shop is great and is only highlighted by the trucks potential as it begins to reveal itself!
Rangers Lead the Way!
- tybob81
Looking good! Dig the louvers.
- Caseys71
, I think they look real nice, both on the tail gate and on the dash. Looks like your truck is really coming along .
Casey
Guys
Thanks for the kind words. The truck is turning out just as I had hoped. Spent Saturday working on the bed and tomorrow night will work on the tabs to bolt the gas tank in the bed as well.
Saturday I will be installing a new clutch, pressure plate and through out bearing and turning the three on the tree to a three speed on the floor with a Mr gasket floor shifter.
Then the wet sanding will start.
I wish i could take credit for the shop. I have some great friends that run a restoration shop that are allowing me to finish the truck at their shop - www.rodsandmods.net
They do great work and have done some movie cars as well - the Yellow cuda in the Bucket List is one of their cars. If you are into newer Mustamgs - they did the killer conversion of old 67 tin on the newer bodies when they were teamed up with Retrobuilt. Great guys all around......plus they let me use their cool tools which make it very easy to do all the mods the the truck!!!
Thanks again and more photos will be psted as it moved forward!
Larry
Larry
- marz68
Love it! When your done with yours you can head out to sun valley ca in your bas a$$ truck and start on mine!
marz68 wrote:Love it! When your done with yours you can head out to sun valley ca in your bas a$$ truck and start on mine!
and when your done in ca. can you come to my place and finish mine.
nice work. i like how you did your dash vent i might have to steal that idea from you
