Harbor Freight Shop Press... Anybody?
72stepside
Post by 72stepside »
Anybody bought or used one of these?
http://www.harborfreight.com/cpi/ctaf/D ... mber=33497
Chris
Hedman Headers
Disc Brakes
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
FORDification
Site & Forum Admin
Site & Forum Admin
Re: Harbor Freight Shop Press... Anybody?
Post by FORDification »
I have that exact same press. It gets the job done, and is inexpensive. I got it mainly for pressing suspension bushings, but have used it for several other tasks. It's not a professional-grade setup by any means, but is adequate for most hobbyists.
72stepside
Thanks Keith. That's exactly the kind of thing I'll be using it for.
Chris
Hedman Headers
Disc Brakes
marxtoys
Post by marxtoys »
FORDification wrote:I have that exact same press. .... It's not a professional-grade setup by any means, but is adequate for most hobbyists.
:yt:
It might not be tall enough to handle axle bearings on a 9" Ford pickup rear - a Jeep axle barely fit.
Tried getting the bearing out of a Subaru knuckle - wouldn't budge... The "ram" - that peg under the jack - mashed itself into that tubing it's stuck to... cut that off and welded a plate there.
Tried getting the bearing out of an Expedition? knuckle and it wouldn't budge... looks like it was starting to mash the tubing that the jack sits on.
Free Pair of Arbor Plates with Purchase.... they're kind of crude. one is a bit thicker than the other.
Still, better than a hammer(press-on-a-stick) for many jobs.
"Knowledge is Good." Emil Faber
72stepside
Bought it today (had a coupon) and already pressed two gears of two Farmall Cub crankshafts. Worked well for that. I can see where it will have to be beefed up for a major job.
Chris
Hedman Headers
Disc Brakes
ToughOldFord
Post by ToughOldFord »
I have that one too, no complaints.
eggman918
Post by eggman918 »
is the shaft under ram hollow , with a solid plug welded to end that contacts work? I have been thinking about one of these,but it sounds like "minor adjustments" will be necessary.....still probably worth the money. Better than the #3 hammer
shortbedCUSTOM
Post by shortbedCUSTOM »
I got one of these about 3 months ago and have no complaints. I've only used it for distributor gears and A arm bushings so far. I second the motion that it's not tall enough but that can be fixed. I would think that all that would have to be done is to extend the legs a little.
-carlos
JMcTurnan
Post by JMcTurnan »
I have that exact same one, you have to watch out every once in a while for pushing king pins out, that cross member is sometimes weak.
ToughOldFord
eggman918 wrote:is the shaft under ram hollow , with a solid plug welded to end that contacts work? I have been thinking about one of these,but it sounds like "minor adjustments" will be necessary.....still probably worth the money. Better than the #3 hammer
I'm pretty sure that shaft is solid.
