Here are some pics of Orange Beezy 1968 F250 Custom Cab 390eng. with "72" front end w/disc brakes C6 trans.
Orange Beezy
- Orange Beezy
Orange Beezy
I WILL KEEP MY GUNS<MY FREEDOM AND MY MONEY!
YOU CAN KEEP THE "CHANGE"!
1968 FORD F250 CC LWB 390 C6 w/1972 front disc brakes
1965 Ford Fastback 2+2 (SOLD)
- Caseys71
Re: Orange Beezy
Looks like you've already got yourself a solid start
. What are your plans for it?
Casey
- Orange Beezy
Re: Orange Beezy
To get it running again soon.Its in pretty good shape.I am the 2nd owner.Got it couple years back from my stepdad.It was an Arizona truck.Did a engine change in it when I first got it 390 to a 390 vin says it had a 360. Only changed the eng cause the comp.was low and burning oil.Kept the org to rebuild it some day.Other than that just gonna keep it stock,well thats what I say right now.Who knows.Put in some sound deading material,new door seals,this week going to put a windsheild in with new gasket and replace the rear window gasket as well.Already swapped out the front drum brakes to disc,best thing I have done to it yet.
- Caseys71
Re: Orange Beezy
Sounds like you've got it all planned out! I'll be sure to keep a close eye on your build up
Casey
Re: Orange Beezy
Normally, I'd look away when seeing an orange vehicle, but I gotta say, I really like the orange on your truck
Sounds like the project is moving along nicely.
1970 F250 Camper Special
