Noob with another question
socalcraigster
Post by socalcraigster »
I had a couple of questions -
I found a 67 hood to replace my rusted 69 for $50. From what I have read, there are some minor differences within the trunk but there is no difference in exterior appearance. Is this correct and will the 67 hood fit?
The same seller also has the side mouldings for a 67. Are they the same as the 69? Probably not. But if it's a good deal should I pick them as well?
Thanks
1967 Flareside Shortbed Crew
1969 390 Ranger Long Bed
Re: Noob with another question
the hoo dis the same except for the skeleton under neath. so it will fit fine. the 67 trim is 1 1/4 wide were the 69 trim could be the 1 1/2 wide or the 3 1/2 wide stuff depending on the model of the truck. is that the parts truck? or is that your truck? we seen that truck on ebay. that is a 69 ranger with no belt line trim. but it does have the lower trim. which is the same for every truck that used it. including the 73-79 trucks. if they used it.
those look like 16 inch wheels and not the 16.5 wheels. since the truck is a F250 it woul dhave 8 lugs so they wouldnt be 15 inch wheels.
Doug F
Post by Doug F »
Also the emblems on the 67 hood are shorter than the 68-72 emblems, so the holes won't line up.
Doug F
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
http://www.pinheadlounge.com/Pinecone
https://www.facebook.com/PineconeDesign
1982 flareside
Post by 1982 flareside »
They could be 15'' 8 lug wheels i got two. On front of Frankenford
Jeremy
1971 Ford F250 camper special 360 T18(old model) 4 speed 4.11 gears 2wd with 1969 doghouse soon to be daily driver FRANKENFORD
1982 Ford F150 flareside 300 T18(new model) 4 speed 4.11 gears 4wd Daily driver
Some people say my truck is ugly and all i say is "Beauty is in the eyes of the beholder.
ForingaMex
Post by ForingaMex »
Doug F wrote:Also the emblems on the 67 hood are shorter than the 68-72 emblems, so the holes won't line up.
I think the mounting studs are the same for the longer '68-72' emblems (with the reflectores in them) as with the shorter ones without the reflectores. The hood that I bought for my truck had F250 long emblems on it when I bought it and I swapped them out for some F100 short emblems. It's been over 10 years but I don't remember having to drill any holes. I might be wrong though. :hmm: It has happened before. :lol:
-Jake
"Better to remain silent and be thought a fool than to speak out and remove all doubt." -Abraham Lincoln
-02 Dodge Ram Quad Cab
-72 Ford F100 LWB 390/C6 (Retired for now till I can rebuild/transform it)
-2000 Ford Windstar (Family Vehicle)
-92 VW Beetle (Mexican)
the emblem mounting holes are the same for all 67-72 hoods.
FreakysFords
Post by FreakysFords »
THIS IS A COPY / PASTE of Keith's info located here.
There are two different styles of chrome hood letters. The 1967- 1969 style is smaller and has small ribs which run horizontally through each letter. The later style doesn't have the ribs and has a satin-like finish inside each letter. The '67-'69 style is pressed onto clips in the hood, whereas the '70-'72 style is held onto the hood with nuts from the backside.
In this photo, the '67-'69 style is on bottom and the '70-'72 version is shown on top. Because of the difference in size and mounting pin location, they are not interchangeable.
All that said, 67 will be fine on a 69 and it's lettering.
Across the board, the only real difference from the exterior is the lettering. My 69 has a 70 to 72 hood, which I hope to swap for a 67 to 72 later, just for the lettering (or I can just repair and redrill).......... Either way, it's a minor difference and not applicable in his year model truck to donor.
Frank
edit my post above: the reflector emblems are the same distance for the mounting holes. the hoo dletters are different as stated above.
ForingaMex
Hey Freaky, That information pertains to the letters.
Doug F was talking about the emblems and that is what I replied to. The letters where never mentioned.
-Jake
FreakysFords
Yah, sorry should have been more specific. Was trying to show that the only exterior difference was the lettering on the hood.
