Keith is it possible to have a truck like this
Re: Keith is it possible to have a truck like this
72 trucks did have the correct disc brake brackets put on them after mid 1971 after serial number M00,001 i think. that is when the steerign linkage and pitman arm was changed. so it must be when the disc brake line bracket was started to be used too.
- FLASH 1
WHEN Loading the chassis up on the truck for Ford Carlisle noticed the bracket for front brake hose has been altered, what they did was turned it upside down since I cleaned the frame and now you can see where it was with cut marks so it something you have to stare at severl times to get the whole picture
Tom, where Ford Trucks Rule
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
1997 F-450 7.3 with 85,000 original miles
2006 F-150 Crew Cab
2008 F-650 Crew Cab Roll Back 6.7 Cummins
2020 Flat Top Peterbilt Roll Back PX-7 Engine
and 2 cars 1968 XLT and 2017 Mustang
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
2006 F-150 Crew Cab
- tybob81
![Worthless without pics :nopix:](./images/smilies/icon_worthless.gif)
- papabug71
IIRC, the DSO was two digits. If the truck was a special order from a customer, the DSO was then changed to the order #. That could be the reason for the odd #. . .FLASH 1 wrote: DSO Code # 7500088 which that I have no info on the DSO #'s
![Image](http://i42.photobucket.com/albums/e340/bigmacdak/papabug71sig2-1.jpg)
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
