How much weight
jp2005
How much weight
Post by jp2005 »
How much can a 1968 Ford F250 pull? Weight? thanks
Caseys71
Re: How much weight
Post by Caseys71 »
Well the GVW's for '68 2WD F-250s range from 6100-7500 lbs. and a '67 2WD F-250 Style-side has a curb-weight of 3815 lbs. meaning you can add an additional 2285-3685 lbs. Which I would translate into, 2285-3685 lbs. of tongue weight which is quite a bit of tongue weight or 2285-3685 lbs. of a load on the truck in total. You can determine your factory GVW by decoding your VIN. To decode your VIN go to this page: http://www.fordification.com/tech/VIN68.htm f
And for more info. on Curb Weights you can refer to this page: http://www.fordification.com/tech/dimensions.htm
Casey
flyboy2610
Re: How much weight
Post by flyboy2610 »
Set up right, it could pull a box car! Getting the load moving isn't the issue. Getting it stopped is!
How good are your brakes? Will you be on any hills?
Caseys71
Re: How much weight
Post by Caseys71 »
Good point flyboy! Stopping is definitely something to consider when towing any kind of load, that and knowing how your truck handles with the trailer behind it.
Casey
jp2005
Re: How much weight
Post by jp2005 »
Well im running brand new shoes in front and the back are in great shape to. I wont be on any hills all highway, also have 390 engine!
cep62
Re: How much weight
Post by cep62 »
Tell us what you want to pull ,then we can give a more accurate answer.
What engine and tranny do you have ?
It's not how much it can pull .it's more about stopping and handling. :2cents:
jp2005
Re: How much weight
Post by jp2005 »
390 engine c6 trans, trailering a 69 f100
cep62
Re: How much weight
Post by cep62 »
If you're pulling often I'd think about trailer brakes and a tranny cooler.
if only a time or two, you should be fine. :2cents:
jp2005
Re: How much weight
Post by jp2005 »
Thanks that helps!
