F600 dash tak drives.
- flywheel
I hear a bit about this, Why don't people go get a dis out of a old truck? or convert a dit out of 60's chricraft? i have a 63 Chris craft with 2 427 Fe fords and they both have tak drives on them, no vac advance. but that should not be hard t fix. Anybody try this?
My truck is low cuz I am short.
- bluef250
Re: F600 dash tak drives.
I think both the heavy truck (361) and 427 dizzies are different than FE.
- flywheel
I might be on to somthing with this boat distributor. I will take pics,
the Ft distibutors will not fit in the Fe engines. that is why the cable drive tachs arent a good choice to use in the light duty trucks most are restoring/building.
Because the mechanical drive tachs don't go high enough for 99% of engines. They were made for the 4000 redline of the truck motors.
- 1982 flareside
Dont hold it to me but i think boat motors run backwards. NOT FOR SURE THOURGH.
Jeremy
1971 Ford F250 camper special 360 T18(old model) 4 speed 4.11 gears 2wd with 1969 doghouse soon to be daily driver FRANKENFORD
1982 Ford F150 flareside 300 T18(new model) 4 speed 4.11 gears 4wd Daily driver
Some people say my truck is ugly and all i say is "Beauty is in the eyes of the beholder.
- Caseys71
I think that that is the case in a dual engine equipped boat, and in that case only one turns opposite though. Atleast that is the way I remember it1982 flareside wrote:Dont hold it to me but i think boat motors run backwards. NOT FOR SURE THOURGH.
Casey
![Image](http://www.fordification.com/images/forum/011-12.jpg)
Twin inboards engines have one engine thats turns backwards, to use the dizzy you would only have to change the drive gear.1982 flareside wrote:Dont hold it to me but i think boat motors run backwards. NOT FOR SURE THOURGH.
