1967 F100 Truck parts
Re: 1967 F100 Truck parts
ignition switch is 67 only. the door locks are actually used from way back upto 79 and then the door locks in the 80's were a different key. then sometime in the 80's ford went back to one key fits everything. how ever on the door locks the tab the works the lock. is only 67-72.
What about the connector/plug for the ignition switch? What the radio antenna assembly?
wiring is 67 only. to fit the 67 only ignition switch. the arrow hollow type radio antennas i think where used from 67-69 in 70 i think the steel whip type antenna was used. there was also a dealer add on kit for the radios and those antennas were a round base antenna instead of the regular rectangle base antennas.
OK, I think someone cut plug w/wires little on the short side. But I'll know when I install the wiring harness after sanding and painting. It was red and yellow wire.
in this post is a 67 only switch plug. you can see the red and yellow wires on it. http://www.fordification.com/forum/view ... ug#p469181
yes same plug w/wires.
What about power steering for a 302 in FE truck?
1969 was the first year for a small block in a truck. the 352 was the only V8 engine available in 1967 in a truck. i think 1978 was the first year the 302 was used in a truck.
so I need the 302 pump and brackets from a 302? What years will work on a 71 torino 302?
ford used matched pulleys brackets and spacer for each certain car truck or engine. i edited my post above.
Besides the different size hole under the hood on the 67. How you tell the difference between the 68-69 hoods to 70-72 on hole spacing on the hood letters?
the letters are larger on the 70-72 hoods than the 67-69 hoods. spacing should be pretty close to the same.
My hood has no letters on it. Someone covered them. Thats why I asked. Its not 67 hood either.
i wwould have to look at the underside of two hoods to verify spacing. but the letters should line up with the holes in the inner skeleton of the hood. that way the nuts for the 70-72 hood can be used. i need to look at a 67 hood to verify the holes in the skeleton of that year of hood. i will have to get back to you unless soemone else has a picture to show you any differences in the two hoods if any.
Where should I get the white paint at? Carquest? Auto Body Suppliers? Should I get it with hardner in it?
