67 grille parking lights
davbell22602
Post by davbell22602 »
I have a parking light housing that wont come out unless i cut the flat head screws with bolts cutters. The flat head part inside the housing turns. I thought about replacing them stainless steel bolts. Any other ideas
quantumleap
Re: 67 grille parking lights
Post by quantumleap »
there might be a little hex screw on the back that you need to hold onto while trying to loosen the housing( better done with grille off)
Daniel--67' reg cab black shortbed/fe/4spd/ford 9
davbell22602
quantumleap wrote:there might be a little hex screw on the back that you need to hold onto while trying to loosen the housing( better done with grille off)
Already been through that. The grille is off. The bolts look like nails with threads.
quantumleap
drill em out and just use bolts or a self tapping screw
davbell22602
ok
put soem sort of rubber washer around the new bolt before you put it throught the housing. that may help keep moisture out of the socket.
