bump side / dent side / ?
big block
Post by big block »
bump side // dent side // what is a 65 f-100 ???? easy i know i am setting myself up for something
69 bronco 4x4 - 70 bronco tube chassies 4x4 351-w c-6 - 65 f-100 w/69 429- c-6 - 03 ranger 4x4 - 99 f-350 4x4 diesel
mlheppl
Re: bump side / dent side / ?
Post by mlheppl »
That era trucks are called slicks I believe.
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
guerra
Post by guerra »
its a slick
1967 f-100 lwb 360/c6
mlheppl
Post by mlheppl »
Speaking of slicks, what would a unibody slick be worth?
Mike
71 F250 4X4
MaxKlinger
Post by MaxKlinger »
61-66 Fords are called "Slicks"
67-72 Fords are called "Bumpsides" or just "Bumps"
73-79 Fords are called "Dentsides" or just "Dents"
The value of any truck varies wildly with your location and the condition of the truck. There are guys in the southwest that scrap stuff that up here in the Rust Belt we'd consider Gold. If you're a seller, it's worth less than you think. If you're a buyer, it's worth more than you think. :D
Tony
'05 Focus ZX4 ST - 2.3L, 5spd
Mancar1
Post by Mancar1 »
I used to have a 65 back in 80 - 88. It had a 67 T-Bird hopped up 390, C6. I called it fun and fast. :drive: Sure did hate to part with that one. :cry:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
big block
Post by big block »
i did a blue book value on my 65 l/b 2 wheel drive i could not believe 11000.00 retail 17000.00 high retail !!! good thing he caught engine on fire with a dry rotted hose over dizzy. so reduced my price alot!! i was very surprized worth that much i will be looking for them now! :D
