oil question
oil question
will it hurt to run a 15w-40 weight oil in my fe engine i live in west texas.
65 F100 swb 302 project
67 dodge coronet 440 also wife's car great mopar though
2005 dodge ram 3500
2008 dodge ram 1500 cc
2005 dodge ram 3500
Re: oil question
you should be just fine.
Re: oil question
thanx
2005 dodge ram 3500
2005 dodge ram 3500
- mlheppl
Re: oil question
Has your motor been recently rebuilt, or does it have a lot of mileage on it? I'm no expert but not sure I would run the 15W-40 on an old engine. 15W-40 is a high detergent oil IIRC formulated to keep diesel engine clean and free of sludge and gunk. If you've got a high mileage engine with sludge buildup, the high detergent oils will start breaking the sludge and gunk loose and you could potentially end up with some problems.
If your motor is pretty fresh and clean, then 15W-40 would be fine to run. Just my
Mike
Mike
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
71 F250 4X4
Re: oil question
I could easily be wrong, but I don't believe that 15w-40 will have extra detergents just because it's 40 weight. Now, if you go with something formulated for diesels, like Rotella 15w-40, then I think you are absolutely correct. Maybe someone will chime in that knows for sure.
