crewcabfan wrote:hi. i don't think the problem is the drive cycle, i think something is preventing the computer from allowing to run monitors.
i was looking at the acura drive cycle and noticed that the first condition you have to met is a cold start, from the computer's point of view the ambient temperature sensor and the coolant temp sensor must be within 5 degrees of each other or monitors wont begin running. i've seen some weird ones at my shop..
I'm starting to agree, however, I was messing around with the Coolant Temp Sensor (AKA Engine Coolant Temp [ect]) and set a code today, so I had to clear it inturn resetting all readiness monitors. Did one cold start with ECT, IAT and Outside temp all within a few degrees of each other and EVAP, and heated O2 set ready within 3 minutes, so it is running at least some monitors.
I'm starting to think it wants to see a higher ECT than I'm getting (85-86C [186-187F]) I'm finding varying stories about what a Honda wants to see but many new cars run a 195 thermostat so I would think around 200 would be better, might try blocking the radiator and see if i can get it in the 200 range for a 5-10 minute steady cruise.
BTW it is O2, Catalyst and EGR that aren't ready, near as I can find they are all 2 trip monitors.
If that doesn't work, you may have me on your phone tomorrow...
