dang P.Os
dang P.Os
Doesnt it suck when a PO removes all the emblems and rattle cans the whole truck?? Totally sucks. I just received my F250 and just now realized that it has not one factory emblem.. not even the hood letters!! So i thought it was a camper Special ecause of some of the charactistics. then I saw the back end, Ranger. Can it be a camper special and also a ranger? Like ranger camper special? oh and did 390s come in any way shape or form off the lot in a '67?
Ace
(Past)
1967 F-250 Holly Green 390/C6 (Parted out)
1967 F-100 Holly Green. 352 auto. (totalled)
1979 F-150 Brwn 300 I-6 4speed (SOLD)
(Present)
1967 F-250 Camper Special. Lunar Green 390/C6, A/C ready.
2005 Dodge Ram 1500 Reg. Cab LWB
(Past)
(Present)
- spartman
As far as I know 67's only had 352's.
You sure it is a 67?
Easy way to tell is do you have door lock plungers or just a handle that you move down to lock.
Another way is to look at the heater controls. Do you have 3 knobs that pull out or does it have slide controls.
If you have the knobs and the door handle set up you have a 67 otherwise it is a 68 or newer.
I believe in 68 or 69 the 390 was available.
definatly a '67 I assume that the 390 and C6 were put in later.
Ace
(Past)
(Present)
(Past)
(Present)
- bluef250
Yes, you may have a F250 Ranger Camper Special with a 390 (but the factory engine is more likely a 352). You should try to get the build sheet. It might be tucked into the seat springs. The VIN will tell you the engine.
http://www.fordification.com/data-1967.htm
Camper Special emblems were on the cowling. Some early '68s may have been registered as '67s depending on the State. Check the VIN. What heater controls are on the truck?
I did decode the Vin it had a 352 auto, dana 60 4:10, 6900 gvwr.. and definatly still a '67 it has lever doors and pull controls, and the vin reflects a '67. I just hate that there is no real emblems to tell me anything. I requested a build sheet three months ago, they replied saying the truck needed further decoding, they said because it was rare, or not documented well.
Ace
(Past)
(Present)
(Past)
(Present)
as soon as i find my card reader ill show you what i mean by the emblems. there is none...
Ace
(Past)
(Present)
(Past)
(Present)
- OldBlue67
Re: dang P.Os
yah dang them! (pretends she isnt in the process of removing all emblems/ trim for primeringAmericanMuscle67 wrote:Doesnt it suck when a PO removes all the emblems and rattle cans the whole truck?? Totally sucks. I just received my F250 and just now realized that it has not one factory emblem.. not even the hood letters!! So i thought it was a camper Special ecause of some of the charactistics. then I saw the back end, Ranger. Can it be a camper special and also a ranger? Like ranger camper special? oh and did 390s come in any way shape or form off the lot in a '67?
390s tend to become 352s on the way home. If I remember correctly the only auto trans available in 67 were either FMX or c4s. I remember my 67 parts truck had a blankity blankin Ford-o-matic and I wished it was a c4
I guess I'm confused about whats rare about it. If the PO removed the emblems there should be holes where they were right? then we should be able to figure out what they were from their placement. If they filled them I would think there would still be signs of them on the inside of the pannels. On a 67 the camper special emblems would probably be a PITA to get to however.
~Liz
Old Blue Truck is Old and Blue
Ugly as sin but dont get in my way VA-ROOOOOOMMMMM!!
- tazzman68
- tazzman68
- tazzman68
She's doin alright, got the interior torn out right now to do some floorpan repair, and some interior mods. After the repairs are done, I have a set of nice racing buckets, and harnesses for it, and I'm gonna throw in an 8pt cage while I'm at it, Jegs has one for less than 2 bills, and it is designed for the fairlane/torino.spartman wrote:I see.
Hows the old fairlane doin lately?
