PICTURES
Re: PICTURES
the easiest way i found is to open a photobucket.com account
- amishbuggy
Re: PICTURES
Open a photobucket account, once you upload and save your pictures on photobucket you simply mouse over the pic you want and you will see a drop down menu, click on "IMG code" and "Ctrl C" with your key board. When you go back to the post you're working just click in the text area and "Ctrl V" with your keyboard and tada your image will appear in your post as soon as you preview or submit, in the edit area you will just see the html code.
If you don't get the drop down menu on the photobucket img just click the img and it will open a new page, look to your left and you should see "IMG code". Also in case you don't know, "Ctrl C" = copy and "Ctrl V" = paste. And it is best to have photobucket & fordification in the same window with eash having a tab instead of opening two windows, it's just a little quicker.
I hope this helps.
Pat
I hope this helps.
Pat
Re: PICTURES
ok thank you very much
- Mancar1
Re: PICTURES
You can also open your pic. in paint, photo shop or whatever program your system has. Click on image, then on resize. Check the pixel spot and reduce the pixels down to what size this forum accepts. Save the resize, then you can add it as an attachment to a post. Hope I didn't confuse you,
cause I just confused the heck out of myself.
For a bunch of photos, I would think Photo Bucket would work great. I just like the old fasioned way.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
