1967 F100 Truck parts
Re: 1967 F100 Truck parts
do u still currently have seat im interested how much u want and do u know anyone with a hood??
thanks djparsons00
thanks djparsons00
What seat? I dont have seat for 67 yet. No on the hood too.djparsons00 wrote:do u still currently have seat im interested how much u want and do u know anyone with a hood??
thanks djparsons00
What years can I use for inside door panels?
- Caseys71
'67 is one year only.davbell22602 wrote:What years can I use for inside door panels?
Casey
What about 4bbl intake? Any FE engine 360,352,390, etc fits or just 360 /390? Its going on a 360.
- Caseys71
To the best of my knowledge any 4bbl intake would work as long as it's from the FE family. (352/360/390) And your best bet is to find a '60s Fairlane with a 390 if your looking for a factory 4bbl intake.davbell22602 wrote:What about 4bbl intake? Any FE engine 360,352,390, etc fits or just 360 /390? Its going on a 360.
Casey
Doesnt matter if its factory or not just long it works.
intakes quoted here.
Hawkrod wrote:AS noted, any intake for an FE will fit, even low and medium risers (they are for a 427 not a 428). There are some port mismatches between the various stuff but it isn't an issue and Ford even used tall port intakes with small port heads! The only FE intakes that do not fit are high riser, tunnel port, and SOHC. Hawkrod
How do I tell if its a high riser, sohc, and tunnel port?fordman wrote:intakes quoted here.Hawkrod wrote:AS noted, any intake for an FE will fit, even low and medium risers (they are for a 427 not a 428). There are some port mismatches between the various stuff but it isn't an issue and Ford even used tall port intakes with small port heads! The only FE intakes that do not fit are high riser, tunnel port, and SOHC. Hawkrod
if the carb wants to stick out of the hood i guess. it is a sight thing. you can tell how tall the riser is by looking at it.
Will a square bore Edelbrock 1406 fit on a ford FE 4bbl intake?
What about the cab and inside cab stuff like the headliner, hdeadliner trim?
the onl yreal differencve in the 67 cab vs the others is where the heater controls are at and wheather it is a deluxe heater or a fresh air heater. other than fuel tank bolt holes and seat belt holes the 70-72 cabs are pretty much the same too.
