More done on the 72'...
- 71 side step crazy
Re: More done on the 72'...
That's looking great bro can't wait to see more
- zakt
got one of the new sections cut out of the old truck... just need to pull spot welds and scribe and trim it to fit and weld.. simple right
1972 Ford F350 crewcab
- zakt
started working on my billet F350 emblems again... now that I have Pro-E
- FormerMarine1981
Those emblems would be awesome man. You could probably sell those on here Easily. How hard would it be to change whats in the center of the emblem?
- zakt
should be easy I will have to see if the font is in the system if not could be alot harder to manually make all the numbers
- 1971ford
very nice project you have there
- zakt
just got back from pick-n-pull got the rear gas section out of a 95 truck and the (2) square *red* supports out of a 71 (5 hrs of hand cutting )
- Fordman5
I wish I could weld like you can... I have some things I want done to my truck and I have to pay to have it done, but most I can do on my own, OR, keep doing it till its right. :p
- zakt
- zakt
Decided to make a winch mount for my 72... Getting a warn M15000 and so far here it is. I used to have a combo kit on my 85' F350 and liked the look of it so going that route on the 72'. Going to get it laser cut out and bolted up.... so far believe Im putting stainless brush gaurds on it but have to see cost etc vrs chrome....
- mybros71
Hey Zakt, what drawing program are you using? I can't tell from the pic if that's a solid object or 2d isometric. Just curious, drawings look good and make it easy to see what you're talkin' bout.
By the way, nice job on the bed patch. I used a Spal fan on a 58 short bed I built. I was super impressed the first time I put power to it. It spun up with authority and put out some wind.
2006 Mustang GT (Wife's)
1962 Comet Custom (Wife's)
- 67mann
Nice project.....Your garage must be HUGE you have a lot stuffed in there
- zakt
Im using ProE (pro engineer) it is a 3d solid... We have a laser cutter and bender at where I work so I just purchase the material The garage is a 4 car but probably closer to a 5 with the over sized sides and middle also one is 24' long and the other 22' (so the long bed dually fits). Heres what were looking at for a final product just need to nail down the width I want and put the sides and brush bars on.
Yea I heard the spals are real good thats why I went that way also. And BeCool radiator is using those also and is actually using the (2) fans I have on mine. They had theres just mounted on a flat piece of material but took mine to the next level
- zakt
Here is the be cool set up with the radiator for ours and the same fans that are on mine. Bunch of thoughts with there set up, fans to close to the radiator alot of openings... so figured mount them away from the surface and enclose the whole thing so would pull air through the whole area
