'67 F100 stepside - full resto new photos 03/03/2013
- BobbyFord
Re: '67 F100 stepside - full resto project storyboard
Nice work, looks good
- 67nukeford
Stephen, good info on the cab corner. I may be in the same spot as you, so this will be very helpful!!
- 67mann
looks very familiar
http://www.fordification.com/forum/view ... 22&t=31245
Great job on the cab restore Keep up the great work
- stephen44
yes it does - so you'll know my pain ! - why they don't make inner cab corners - I just don't know - if the outers have gone you know the inners have gone too
It seems like this job will never finish - as fast as I think i an nearing the end - I find another bunch of rust.
I decided to this properly and am sanding and blasting every bit of rust off the inside and outside - these '67's are worth saving.
But don't think I don't think - "why didn't I just bomb it with rustoleum"
keep up the good work on yours - I follow your steps with interest too !
- Stephen
- Stephen
thanks
Stephen
Stephen
- stephen44
well - I no you all thought i'd given up - but no - just took a break over winter
Finally got the cab finished - still have some dents to take out but got it into epoxy last weekend
(You can click on the photos for a bigger image)
thanks
Stephen
Stephen
- stephen44
then got the frame sand blasted
thanks
Stephen
Stephen
- stephen44
tomorrow I will epoxy and the next day - coat in SPI bedliner - stay tuned - you'll all be surprised I think
Chris is still sticking with me - putting in as many hours as me - 2, 10 hour days
thanks
Stephen
Stephen
- stephen44
tried lots of different ways to support the frame for painting - my old old back is no good on the ground
came up with this - don't laugh - it will work and I will be able to walk
thanks
Stephen
Stephen
- mark F-100
Looks like your doing a great job.There's lots of work,in doing a frame off. Keep up the good work.
- stephen44
so onwards with epoxy - my home made rotisserie works great - with some mods
thanks
Stephen
Stephen
- stephen44
I really love that SPI Epoxy - a glass like hard as nails - black finish
bed liner tomorrow - hope you like the color
thanks
Stephen
Stephen
- stephen44
Sprayed the bedliner on - boy does it look good - It feels so good to have done something constructive
remember this si how it looked a long while ago
click on images for larger view
thanks
Stephen
Stephen
- stephen44
and the chassis
thanks
Stephen
Stephen
- stephen44
finally some new stuff instead of repairing
got the king pins replaced (metal) and built a dolly for the cab - and finished the welding on the cab - needs some minor body work - but onto the front suspension rebuild next weekend - hopefully - you know how "honey-do" lists can get in the way !
thanks
Stephen
Stephen
- Florian
Dig the red bedliner! Black gets boring down there
1971 Ford F100, 302cui, 3 on the tree
