igniton problem
wn. 68 ranger
igniton problem
Post by wn. 68 ranger »
if the key is a little stiff left and right can a guy put door lock lube on his key and insert and loosen it up or am i gonna have damp ignition problems thanks mike :hmm: :hmm:
390Nut
re: igniton problem
Post by 390Nut »
Find some graphite. Or make your own, by grinding up a pencil lead.
Graphite is the lock lube of choice, specifically because it doesn't introduce moisture into the mechanism.
You should be able to get it at your local Napa, or other local parts store. Comes in a small tube, just like Loc-tite.
`69 F100 390 4spd driver
yes graphite is the only way to go.
