The 5.0 Is Almost Ready
JMcTurnan
Post by JMcTurnan »
Been working on engine for about a week now, it used to be covered in a 1/4" film of oil haha. Not anymore. It came out of an 84 Colony Park, the Aod is already installed with the 5.8 and running and driving. However, I am looking for a little more fuel economy, so I am down grading to the 5.0 2bbl. New heads and intake are on, and re installed every gasket on the engine.
forrestbump
Re: The 5.0 Is Almost Ready
Post by forrestbump »
Nice lookin' Windsor! Much success with your project. :thup:
Larry
BobbyFord
Post by BobbyFord »
Looks good! Always nice to get some freshly painted iron under the hood. Did you replace the rear main and freeze plugs,too?
JMcTurnan
Post by JMcTurnan »
Freeze plugs were all perfect, the deep cup type which is the kind I like. The rear main no, just hoping it don't come back to bite me in the butt lol.
JMcTurnan
Post by JMcTurnan »
Done, all that's left is to install and swap out plug wires.
hazelnut
Post by hazelnut »
JMcTurnan wrote:Freeze plugs were all perfect, the deep cup type which is the kind I like. The rear main no, just hoping it don't come back to bite me in the butt lol.
If its a one piece seal you could change it before putting on the flex plate :thup: Would suck if it leaked after you get the motor in.
BobbyFord
Post by BobbyFord »
Speaking of flexplates, make sure you use the flexplate that came with the 5.0 and not the one that's on your motor now. The flexplates changed balance in '82.
JMcTurnan
Post by JMcTurnan »
It's a 2 piece seal. Yea definitely on the fly wheel. This is the original engine that was paired with the AOD so the flexplate on it and spacer are natural to the engine. I had to get another flywheel for the 5.8 when I installed the engine.
Fo-Mo-Co
Post by Fo-Mo-Co »
JMcTurnan wrote:It's a 2 piece seal. Yea definitely on the fly wheel. This is the original engine that was paired with the AOD so the flexplate on it and spacer are natural to the engine. I had to get another flywheel for the 5.8 when I installed the engine.
I thought they had switched to a 1 piece seal by 84. Did you ever look at the casting numbers on the block?
"We don't want tradition. We want to live in the present and the only history that is worth a tinker's dam is the history we make today."
Henry Ford
BobbyFord
Post by BobbyFord »
I believe that's correct, one-piece seal after 82.
JMcTurnan
Post by JMcTurnan »
Okay I wouldn't know haha. Your probably right, I can't tell because I have never taken off the fly wheel or flex plate to look lol.
BobbyFord
Post by BobbyFord »
If it is a one piece, it's about a $15 seal and can be replaced in about 10 minutes. Not a lot of time or money for a little bit of insurance (compared to pulling the trans to fix the engine oil leak 10,000 miles after you put the motor in). :2cents:
JMcTurnan
Post by JMcTurnan »
Is it one of those that look like a front main seal that you just take a screw driver, and pop it out and top another in? Sorry I have never worked on a ford engine past a 77.
BobbyFord
Post by BobbyFord »
JMcTurnan wrote:Is it one of those that look like a front main seal that you just take a screw driver, and pop it out and top another in? Sorry I have never worked on a ford engine past a 77.
It doesn't have a lip to get the screwdriver behind. If you're VERY VERY careful, you can drill a tiny hole in the seal, close to the block not close to the crank, and screw a small sheet metal screw into the hole, then use pliers or dykes to pull the seal out. You may have to drill two holes and use two screws (at 3 o'clock and 9 o'clock). Be extremely careful not to nick the crank. You can use a small hammer and carefully tap the new seal into place, using the old seal backwards to strike against.
JMcTurnan
Post by JMcTurnan »
Alright thanks!
