5 SPEED
foghorn
5 SPEED
Post by foghorn »
What 5 speed is a direct bolt in behind a 302 if any. This is for my son's truck it has a 3 speed right now.
Foggy 8)
Work is for people that dont know how to fish
cdeal28078
Re: 5 SPEED
Post by cdeal28078 »
Many of them are if you have the right flex plate, bell housing and input shaft. IF you get everything except the flexplate from a 5.0 Mustang I would think that would be a pretty much bolt in deal except for the tranny mount and drive shaft. Fles plate will need to match the bell housing in tooth count and size and balance for your older 302.
A lot more out there know much more than me though so wait to hear from them
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
eggman918
Re: 5 SPEED
Post by eggman918 »
the M5odr2 has the small ford bolt pattern it is in F-150's from late 80's to mid 90's with the 4.9L6,5.0 and 5.7V8 :2cents:
Steve.
foghorn
Re: 5 SPEED
Post by foghorn »
Well i guess we will have to maybe change the trans mount maybe the drive shaft and go to the hydro type clutch. I think from 1980 on they went to this type of clutch in the trucks. Any more info will be very helpful.
Foggy 8)
eggman918
Re: 5 SPEED
Post by eggman918 »
My truck had the 4 speed and the drive shaft needed to be shortened and the cross member moved back aprox 4" the M5od uses the same slip yoke that a C4 uses,might be the same as 3 speed :? clutch is hydraulic but not too hard to retrofit.Hope this helps.
Steve.
foghorn
Re: 5 SPEED
Post by foghorn »
Eggman is that part on the clutch pedal made from channel iron and flat plate?
foggy 8)
eggman918
Re: 5 SPEED
Post by eggman918 »
plate oops 1"x2" bar with a slot in it for the peddle to fit in
Ranchero50
Re: 5 SPEED
Post by Ranchero50 »
Tremec TKO or 3550 will bolt up, might need a different clutch disk and driveshaft yoke depending on which tranny you end up with.
