wierd VIN number
1976-f250-hignboy
wierd VIN number
Post by 1976-f250-hignboy »
ive found a 68ish f100 swb the body is super straight but no motor or tranny. but while lookin at it i looked at the vin number. it started as H10AKA....yes i said H. so it was originaly a 240 6 cyl....but whats up with the H? supposed to be a F10.....any ideas or suggestion?
Re: wierd VIN number
check that the frame vin matches the door warranty plate.
1976-f250-hignboy
i looked for the frame VIN. i couldnt find it but there was a lot of grease and oil caked on frame. where is located at exactly?
usually on the front passenger side frame rail in front of the engine crossmember. you need to clean it off good and then push the inner fender out of the way to see ift the best. edited sides.
mrollings53
Post by mrollings53 »
It's on the passenger side.
UNCLE BOO
Post by UNCLE BOO »
mrollings53 wrote:It's on the passenger side.
[ Image ]
Hey! I didn't know about that one under the cab! :eek: I have the cab off my '68 right now.....I'll go take a look. (MY door VIN matches the one on the front frame rail...so I expect the other one to match as well.)
Does anyone "protect" these frame rail VIN's when doing a restoration? If so, what is recommended? POR or an Eastwood product, etc., would cover them over, I would think.
Cheers!
1953 F100
1972 F250 Ranger XLT/390/Longbox
1968 F100 Ranger longbox (project)
1966 Mustang Coupe / 289-4bbl
1975 Mercury Cougar XR7 / 351M w/351 cleveland "Aussie" heads / 4bbl
the vin would only be in one place on the frame. i have never seen it under the cab. i put spray paint ove rmy vin when i had the front clip off. it didnt help to protect it much. it was just silver spray paint. i would paint over the vin just as you were goign to do with the rest of the frame. most guys are putting por 15 on the frame.
UNCLE BOO
Post by UNCLE BOO »
fordman wrote:the vin would only be in one place on the frame. i have never seen it under the cab. i put spray paint ove rmy vin when i had the front clip off. it didnt help to protect it much. it was just silver spray paint. i would paint over the vin just as you were goign to do with the rest of the frame. most guys are putting por 15 on the frame.
Yeah, I guess it isn't going anywhere, anyway! If someone down the road wants to see it, THEY can scrape the paint (POR) off! :)
Thanks, Fordman!
1953 F100
if the por is put on light enough it wont fill in the numbers.
mk
Post by mk »
Sounds like just a stamping mistake. Rare, but I've heard of a fair amount on Mustangs and seen a few on our trucks. Frame number will probably show correctly.
mike
~Will Rogers
Mercury truck ID thread:
Ford truck model history:
Using dentside fender liners:
Matchbox diecast bumps:
