So I go to leave to cut lawns this morning after letting my truck run for a bit and notice a puddle under the engine.....diesel fuel.
I just replaced the mechanical lift pump in the valley of the engine back in June, and then did the high pressure fuel lines not long after that. So the pump and all rubber lines on top of the engine are relatively new.
So far it looks like I bought a faulty pump, but I am hoping I just over tightened a hose clamp and that it cut into a hose.
I thought those 7.3 Powerstrokes were supposed to be reliable and last for 600,000 miles. Guess just not mine.
When does it stop?
OT Arrrrrg!!!! *Bangs head against wall*
- OldRedFord
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Re: OT Arrrrrg!!!! *Bangs head against wall*
The impression I always got from the 7.3 PSD crowd was, sure, the 7.3 will last 600K and more. It'll just take $20K in maintenance to get it there. I don't like all the things that go wrong with a 7.3 fuel system that cause it to not run.
- Ranchero50
It stops when you drop in a 6bt...
You were warned, remember?
Jamie
Jamie
- basketcase0302
What's lacking there Tim, I can't remember?Or that voice in my head that says "Dangit why didnt you finish the F100 first..you would have a backup vehicle"
- OldRedFord
I need a proper truck transmission and not a Lincoln one, then a drive shaft carrier bearing bracket. Two new freezeplugs in the block.basketcase0302 wrote:What's lacking there Tim, I can't remember?Or that voice in my head that says "Dangit why didnt you finish the F100 first..you would have a backup vehicle"
Tim
- basketcase0302
Is it a C-6 automatic you need for the 460?I need a proper truck transmission and not a Lincoln one, then a drive shaft carrier bearing bracket. Two new freezeplugs in the block.
I do remember the freeze plugs now.
The carrier bearing bracket would come new as a whole if I'm not mistaken?
- OldRedFord
Yup, would like to get a C6 with the correct tail shaft for a truck.basketcase0302 wrote:Is it a C-6 automatic you need for the 460?I need a proper truck transmission and not a Lincoln one, then a drive shaft carrier bearing bracket. Two new freezeplugs in the block.
I need the part of the bracket that is riveted/bolted to the frame.
Tim
- rjewkes
you might be able to one piece the driveline if you get one from a later 70's f-series truck with the same Drive line length.as i imagine that piece will be hard to find.
