70-95 body swap is on the road!
70 ranger
Post by 70 ranger »
Well it`s been about three years and a lot of work but I insured it and have been cruising all weekend in the old bump! I won`t say that its done but it is driveable. I haven`t installed the air conditioning yet and I still have to finish off some wiring. Oh ya and it needs a wheel alignment... and the tim put on. But who cares I am cruisin! My picture files were to big to download so I will figure that out later.
I put some pictures on my photobucket link below.
1970 ranger 4x4
1965 mustang needs resto
flh shovelhead
rigid evo
wt4speed#2
Re: 70-95 body swap is on the road!
Post by wt4speed#2 »
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
hazelnut
Post by hazelnut »
wt4speed#2
glad we posted differnt pics lol
Tony B.Image
DFW Area
"Someday...
Member#'s 236 & 403
wt's ride
thebucket
hazelnut
Post by hazelnut »
wt4speed#2 wrote:glad we posted differnt pics lol
:yt: :D
70 ranger
Post by 70 ranger »
Thanks guy's, I needed a little help!
1970 ranger 4x4
flh shovelhead
rigid evo
wt4speed#2
it's easy just got to the photo on photobucket you want to share. hit the drop down and copy the img link and then paste it in the typing field in the thread you are posting in
Tony B.Image
DFW Area
"Someday...
Member#'s 236 & 403
wt's ride
thebucket
OldRedFord
Post by OldRedFord »
How far off were the body mounts? How much room on the sides of the engine?
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
70 ranger
Post by 70 ranger »
OldRedFord wrote:How far off were the body mounts? How much room on the sides of the engine?
I put in new floor boards and cab mounts then drilled the holes where they needed to be, about 2" back and 3/4" wider. the rear cab mounts I drilled out new ones in the cab to fit the new frame. I used a 300 six motor so I had no width problems. I put the cab about 3/8" from touching the head then installed the rad support to check to see if I had eneuph room. I know this doesen't sound to scientific but it all worked great.
1970 ranger 4x4
flh shovelhead
rigid evo
ezernut9mm
Post by ezernut9mm »
freeckin awesome. i like your firewall adapter plate for the wiring. good job mang/
mk
Post by mk »
Ford did set the engine back a couple of inches starting in 80. We discovered this on my cousins truck when he did a 67 body swap on to a 95 2wd chassis.
Nice work; now I'm even more motivated to strip the 89 4x4 I've got and throw my extra 69 cab on...
mike
~Will Rogers
Mercury truck ID thread:
Ford truck model history:
Using dentside fender liners:
Matchbox diecast bumps:
tybob81
Post by tybob81 »
:rock: Sweet swap and great ride!
