76 ford van parts swap.
champdog
Post by champdog »
Good morning. Im not sure where to post this because its in several categories. But I found a 76 ford van for a good price. What parts will swap if any. Im lookg to do front disks, Intermittent wipers, seats possibly, and get the motor and trans. Again If swapable. ????? Thanks Champdog
68 F-100 LB 360
98 f-250 LT 4x4 SB Just sold it. It was a good truck.
Bumpside Collector
Re: 76 ford van parts swap.
Post by Bumpside Collector »
Arm rests will swap out too I think.
CHEESE?!?
Running:
2012 Ford Focus SE hatchback
Not Running:
1967 F-100 Ranger Short Bed
1970 F-100 Ranger Long Bed
ok68crewcab
Post by ok68crewcab »
I believe vans have the rear sump oil pans that the 4x4s use.
2 Blessed 2 Be Stressed
Whateverman
Post by Whateverman »
Bumpside Collector wrote:Arm rests will swap out too I think.
the interior door latch handles swap too
( something i found out recently- aerostar latch handles will swap too,although they're made of plastic )
engines and trans swap in with no problems usually, although c6 van trannys tend to have long tailshafts which will mean you'll need to get either a custom driveshaft or your existing shaft shortened
also : the van engine mounts are different than truck ones (at least the frame stands are anyways..),and sometimes the van exhaust manifolds can interfere with the frame ,steering box and engine stands depending on the engine
van rads work too ,but one of the flanges on the side will need a little trimming and a few new holes drilled
rjewkes
Post by rjewkes »
the same plastic inner door latches are used on 97-'0something extended cabs with the suicide reardoor f-series trucks.
