67 Shortbed 2WD Rebuild
- MattHillFord
Well... My work schedule finial opened up and that means I got time to work on my bump! So Ill keep you guys updated as I work.
Monday, March 26th.
Well, here we go, 352 Ford in a dirty engine bay.... Lets fix that
My work area (Tented because of possible rain)
Pulling out the engine, had a hard time with the 4 speed.
Engines out... wow what a mess
4 Hours later and its MUCH cleaner....
More Thursday
Monday, March 26th.
More Thursday
1967 F100 RWD Short Bed / http://photobucket.com/MattShortF100
1968 F100 4X4 Long Bed / http://photobucket.com/MattLongF100
Project Page:
http://www.fordification.com/forum/view ... 22&t=65244
Project Page:
- mybros71
Re: 67 Shortbed 2WD Rebuild
So what's the plan for this rig?
2006 Mustang GT (Wife's)
1962 Comet Custom (Wife's)
- basketcase0302
Matt,
Good start man. One thing I see is that your missing the hood to cowl gasket that snaps into the firewall. This is a cheap, (around $25.00) part that really helps keep the engine bay clean.
- MattHillFord
My plan for this bump is a complete rebuild, Might take me awhile to get it done... But that's OK.
1. Engine and Engine bay - 35%
2. Transmission 10%
3. Exhaust System
4. Body, Interior, and............. Paint
5. New Engine - 460? or 390?
6. Chassis and Suspension Rebuild for high HP output.
2. Transmission 10%
3. Exhaust System
Project Page:
Project Page:
- mybros71
Sounds like a solid plan! I'm excited to see your progress.
- elgemcdlf
The 390 will bolt in. The 460 will require new mounts. The factory mounts from a '73-'79 2WD 460 truck will bolt in your truck making the engine swap basically a bolt in. I say basically because I have a CV IFS so my 460 swap was a bit more involved. I do not know what you will need to alter if you stay with the I Beam IFS.
- MattHillFord
Had some free time today! Yeah. Lets do some engine cleaning.
Tuesday, March 27th.
Stop by local part shop for some finial parts.
Pulling Fuel Pump, Water Pump, Exhaust Manifolds, and Cleaning off all the grease.
Block cleans up nicely with Oven Cleaner almost ready for paint.
Tomorrow working on rest of engine
Project Page:
Project Page:
- F100builder
Good start and good luck with your project! Keep us posted!
Patrick
- MattHillFord
Got some more work done today! I'm on a roll
Got my Intake back today from a local machine shop, along with a care package from summit.
Took the front end off for paint and frame cleaning.
Front End.
Also changed some old arm bushings..... I'm guessing they have never been changed.....
New ones
More this weekend!!!!
Front End.
New ones
Last edited by MattHillFord on Thu Mar 29, 2012 11:57 pm, edited 6 times in total.
Project Page:
Project Page:
- F100builder
You should think about new cab bushings as well. It'd be easy to do right now with the front clip off. I'm curious...did you have the intake machined or something?
Patrick
- MattHillFord
Its a Edelbrock Street Master that I found in a local junk yard, had it hot boxed, sprayed, ports opened up, and dipped in protective coating.
Project Page:
Project Page:
- MattHillFord
(Edit) Found out thanks.
Project Page:
Project Page:
- MattHillFord
Ok got some more! Today sucked
3/31/2012
Today consisted of cleaning the frame for paint.. lots of degreasing, and sanding.... Still not done.... BLAH
My Dad is giving me me a hand with some frame work, hes the fabricating/welding man around here
Also got more package's from Summit
More Tomorrow!!
3/31/2012
More Tomorrow!!
Project Page:
Project Page:
- basketcase0302
Looking good Matt. The intake and headers and new carb will really wake up your engine!
- MattHillFord
Ok got some more today.
4/1/2012
First part of painting process done today, more tomorrow!
4/1/2012
Project Page:
Project Page:
