Got my 2wd bronco finished
I always wanted a 2wd version and since one was not made I built my own,I picked up a 88 with front hub or transfer case issues to do the swap and if I knew it was that easy would have done it when they were almost new. I plan on lowered beans and a axle flip in the future but it will need a C notch so it will be next year or so before that happens.
- F100builder
Re: Got my 2wd bronco finished
Cool!
Chevy made Blazers in 2WD...most seemed to be from Cali. I wonder why Ford never made a 2WD Bronco??? I like it and it sounds like a good plan to drop it. I think it will look better with a lowered stance. It'd be fun to cruise it with the top off too! Keep us posted!
Patrick
Its got lightning springs up front and some custom rears but still sits a little too high for me,the dropped beams I have are for 82 to 86 balljoints and spindles but am going to look for 87 to 96 beams since I got adjustable caster cams in it now and dont want to give them up. I am going to get some prices on a c notch and maybe in a couple years can get it lower.
- MaxKlinger
Maybe you should take the "4x4" badge off of the truck? It's just below the driver's side headlight.
I think the stance is cool where it is. Did you have to weld to the frame to put the 2WD front end under it?
Tony
'05 Focus ZX4 ST - 2.3L, 5spd
It has been removed after the pics were taken and looking for the 4x2 emblem the 87 trucks with 460s and 351s instead of the EFI emblem.
