1968 F100 Bed interchange
1968 F100 short bed. Just picked one up for my 13 yr old son. Will a 69 F250 shortbed bolt right on the F100 frame?
I have found a clean bed just dont want to get it if its not a bolt on. Both are fleetsides.
- TNIceWolf
Re: 1968 F100 Bed interchange
From what I have read on here it should be a direct swap. Lots of flexibility in these old rigs as well.
Presently in the stable
1969 Ford F-350 DRW
1969 Ford F-350 DRW
Got any pictures of the 69 F250 shortbed?TimB wrote:1968 F100 short bed. Just picked one up for my 13 yr old son. Will a 69 F250 shortbed bolt right on the F100 frame?
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- elgemcdlf
They are the same bed with minor exception being reflectors.
Thanks for the info. No pics. Not in my possession. Dont want to buy and it would not fit. Reflectors coming off anyway. Side marker lights to replace them
- elgemcdlf
If you are doing side marker lights just get a '70-'72 bed. They came with marker lightsTimB wrote:Thanks for the info. No pics. Not in my possession. Dont want to buy and it would not fit. Reflectors coming off anyway. Side marker lights to replace them
good point, just have not found a clean 70-72 bed around
- elgemcdlf
How far are you from Vegas? I can probably locate you 1 near Vegas.TimB wrote:good point, just have not found a clean 70-72 bed around
I am in Northern Ca. 2 hours south of Oregon.
- 67mann
If you have a Flex-O-Matic suspension.....your replacement box must accomidate the rear shackle. My case being that I have a 1970(longbed)frame with the FOM set up.....my replacement box is a 67 and guess what I overlooked
Just a little FYI as I've never seen that fact stated when this Question arises
