72 F100 project, longbed to short conv, CV swap, 20s
elgemcdlf
Re: 72 F100 project, longbed to short conv, CV swap, 20s
Post by elgemcdlf »
I paid $250 for mine. Watch Craigslist for wrecked police cars being parted out or if you want to install the 4.6 and all buying the entire car may be worth it. The local Pick A Part yard has a few most all the time.
mybros71
Post by mybros71 »
I think I'm going go try and bid on a car or two when they get surveyed out locally. I would like to swap front, rear, engine and transmission into a bump. I wouldn't even mind running the steel wheels with the baby stainless caps. I don't have a truck for it and too many other projects but Ford is out of the Crown Victoria building business. They are only getting more valuable. The last one I saw had a crushed quarter and went for 400 bucks. I thought the front end would be more at the junk yard so I hadn't thought seriously about it until seeing your guy's projects sitting on the ground. You guys make it look easy...or at least straight forward.
2006 Mustang GT (Wife's)
1962 Comet Custom (Wife's)
The Big Bear
Post by The Big Bear »
I picked up a 2008 Grand Marquis same as the Vic with the 4.6 motor and complete harness and the rear end cheap, I started a post about my project 67 Crew Cap and Grand Marquis swap.
The fabbing is not that hard and plenty of other guys have done the swap with lots of pictures just do some searches and you can find plenty of pictures. If you do the numbers it is way cheaper than any other option and so far I am really happy with everything.
I found some after market wheels with some serious offset that a kid was running on a car and I have some wide ass wheels and tires on it now for only $300! Lots of parts and options and you can make the 4.6 get around 400 hp with a shot of Nitrous, pleanty for me.
Money wise with all of the Cab companies and Police Depts that the Crown Vics and Grand Marquis they are getting cheaper and more common!
Be grateful for every day :fr:
F100builder
Post by F100builder »
This is such a great build thread...I want a CV IFS, I want a CV IFS, I want a CV IFS!!! :pray:
Patrick
elgemcdlf
Post by elgemcdlf »
F100builder wrote:This is such a great build thread...I want a CV IFS, I want a CV IFS, I want a CV IFS!!! :pray:
Patience young grasshopper (you have to say it like the old guy on Kung Fu). All will come in it's own time.
jetdrive9
Post by jetdrive9 »
What a sweet build ,you are doing a awsome job.I am doing a 66 swb right now.definately getting some great info .
jetdrive9
Post by jetdrive9 »
have a ?is there a issue with using p71 stuff ,i hear the steering rack is wired thru abs system is that true?
elgemcdlf
Post by elgemcdlf »
jetdrive9 wrote:have a ?is there a issue with using p71 stuff ,i hear the steering rack is wired thru abs system is that true?
P71 is just the Police Interceptor version. No big deal either way. The P71 versions are easier to locate but by no means a required. The rack is a variable rate rack that is wired through something. My thoughts would be more like rpm indicators. To date I have yet to hear of anyone actually hooking that up. It is not required. It is adjustable. If you want firmer or less firm feel you can adjust the solenoid. The elec just does it automatically as I understand based on how fast you are going so maybe speed and not rpm. P71 is also used in taxis. Do you have a build thread somewhere? Pics, pics, pics :D
jetdrive9
Post by jetdrive9 »
heck i cant figure out how to put pics on here .i am using a grand marq front on mine and just located a explorer rear .and thanks for all the great pics and part numbers.You anserd almost every ? i had about this swap with out even having to ask.
jetdrive9
Post by jetdrive9 »
i am still trying to locate the long bolts that hold every thing on
F100builder
So, I'm sure this has been mentioned before but what are the desirable years of CV's and GM's for this swap anyway?
Patrick
jetdrive9
Post by jetdrive9 »
Just picked up my 373 explorer rearend :woohoo:
elgemcdlf
Post by elgemcdlf »
F100builder wrote:So, I'm sure this has been mentioned before but what are the desirable years of CV's and GM's for this swap anyway?
'03-'11 CV IFS
jetdrive
Post by jetdrive »
is the 03 to 11 the same cradle?
67F100-390
Post by 67F100-390 »
jetdrive wrote:is the 03 to 11 the same cradle?
Yes they are
67 F-100 Custom Cab Short Bed
428ci 4 speed
Finally runs and drives after 14 long years in a field
