Gas Mileage Question
davbell22602
Post by davbell22602 »
What kinda gas mileage would I get on a 72 F100 2wd, 390, automatic trany, and 8ft bed? Dont know if its 2 or 4 barrel carb.
Ranchero50
Re: Gas Mileage Question
Post by Ranchero50 »
10 is average, loaded or not with some interstate running.
davbell22602
Really? I know I could go from winchester on rt7 to purcerville va and back on a quarter tank of gas in my 72 F100 360 2bbl. with a loose timing chain.
TNIceWolf
Post by TNIceWolf »
And that distance would be how much total for those of us who are map impaired?
Presently in the stable
1969 Ford F-350 DRW
davbell22602
TNIceWolf wrote:And that distance would be how much total for those of us who are map impaired?
24.5 miles one way or 49 miles over and back.
72BahamaBlue
Post by 72BahamaBlue »
Best I could ever squeeze out of my stock '72 F250 360/c6 16.5 x 9.5 tires 60mph, 14.5 mpg.
BobbyFord
Post by BobbyFord »
It all depends on rear end gearing
tmcalavy
Post by tmcalavy »
So in that truck you traveled 49 miles on 4-5 gallons of gas...do the math, that's 10-12 mpg...right in the ballpark...about what you can expect to best you can expect.
Montana71-F100
Post by Montana71-F100 »
I took a 1400 mile road trip when I first overhauled my 71 360 4WD. I didn't know at the time that my vacuum advance diaphragm had a hole in it so, with no vacuum advance, the best I got was just under 12 mpg. That's with points and timing set at 6 degrees BTDC. Since then I've put a new vacuum advance canister on, installed electronic ignition and set the timing at 10 degrees BTDC. I haven't taken a road trip with the new setup so I don't know if the mileage has improved.
MaxKlinger
Post by MaxKlinger »
There are a lot of variables that can affect your fuel economy. But 10-12 as an average is a pretty good number. Higher numbers ARE achievable. I got an honest 19mpg once with my '72. Highway running is usually 15+ mpg for me, and city driving a deplorable 7mpg.
Tony
'05 Focus ZX4 ST - 2.3L, 5spd
BobbyFord
Post by BobbyFord »
I get many SPG's (smiles per gallon) :D
MaxKlinger
BobbyFord wrote:I get many SPG's (smiles per gallon) :D
That's a great way to put it. I like that. :thup:
Tony
Whateverman
Post by Whateverman »
MaxKlinger wrote:There are a lot of variables that can affect your fuel economy. But 10-12 as an average is a pretty good number. Higher numbers ARE achievable. I got an honest 19mpg once with my '72. Highway running is usually 15+ mpg for me, and city driving a deplorable 7mpg.
sounds about right
my best ever with the original 360/c6 in my truck was 17on the hwy ,with 15 being the usual hwy mileage
