F100 body on e350 frame.....????
grebesbakery
Post by grebesbakery »
Alright guys this is an odd questions but I want to know if a F100 long bed body will fit on a e350 frame.....
The reason I'm even considering this bc the van has a healthy 7.3 powerstroke (95'), trans and the frame is in great shape. I know everything won't line up perfect, i'm sure body mounts will need to be moved and wiring will be interesting. As far as wheel base....they look almost exactly the same.....
What are your thoughts????
Kraig
Re: F100 body on e350 frame.....????
Post by Kraig »
One sure way to find out...try it. Powerstroke Bump would be cool.
1969 F100 Ranger LWB Big Block, factory bucket seats and behind seat storage (arrived 3/21/12) (and it was free!)
1986 Thunderbird Turbo Coupe 247K and still going strong! (sold with 251,758 miles on it!)
1986 Comp Prep SVO Mustang (1 of 83) "the original Fox body "R" model!!"
1972 Ford F-100 LWB SOLD 5/2/6
1995 F150 XLT Supercab (wanna trade for a Bump?)
70 ranger
Post by 70 ranger »
[quote="grebesbakery"
I did a swap and I would recommend you make sure exactly what the differences are before you start. You also have to consider steering linkage, shifter mechanism, gas tank issues(filler necks and height of tank), power brake booster, throttle linkage (cable to mechanical), park brake cables and wiper motor if you use the new harness. The frame is probably 3" wider (the trucks are) meaning that the box will not be a bolt on thing either.
Not trying to deter you from this, just saying you want to know what you are getting into before you wreck two vehicles. I did the swap because I am no mechanic. I know my limitations in that area. I am an automotive painter and am surrounded by body men that I got lots of info from before, during and after. They just won't shut up! :D
For me the swap was a great way to go and I have been driving it for 14 months now. The only issues I have had was a fuel pump went south and a burnt out headlight! nothing to do with the swap itself.
Good luck !
1970 ranger 4x4
1965 mustang needs resto
flh shovelhead
rigid evo
71fordkid
Post by 71fordkid »
saw a 79 4x4 f250 come through my shop with a 6.9L IDI in it ther other day. it looks like the perches from the 6.9 truck welded up very easily to the 79's frame...
Ex Ford diesel dealership senior master tech (6 years)
Current bmw level 4 tech.
1972 Ford F100 Stepside - 302, forged TRW flat tops, performer 289 intake, edelbrock 600 cfm carb, CV IFS swap, 4.10 LSD disc 8.8 , AOD 4 speed auto. Currently 5 years in the making.
