Ford's design of attaching the intake manifold to the exhaust manifold on the 240 & 300 engine does not work well down here in the South. It gets hot down here & the winters are usually mild. I've had my share of hot start problems on the flareside, caused directly by excessive heat on the carb. I installed a 1/2" phenolic spacer between the carb & manifold which helped a little. I lowered the float level 3/16" which helped a little. I installed a 1/8" plate between the carb & exhaust runner which seems to have cleared up the problem for now. It will be super hot again next year, but I have plans to nip this problem in the bud once & for all over the winter months.
I am not a design engineer, but I know how to fabricate what I want. See attached photo for my version of a heat diversion plate I plan to fabricate & install between the carb & manifold. I will still use the phenolic spacer on top of my plate. I will have to use longer studs which isn't a problem. I am confident that this upgrade will keep the carb from superheating & boiling the gas over.
My truck starts instantly when cold & runs down the road flawlessly, but shut it off hot, walk away for ten minutes & try to start it back up. It's not that hot today so the truck hasn't been a problem. Have A Great Ford Day!
