I hope Some Of You Smart Guys Are Online
ford4x4fun
Post by ford4x4fun »
Is this the way the motor mount goes back on. I can't remember, and it has been almost a year since I took it out. Having the metal flap to the front changes where the motor sits in the truck by about 2 inches. Thanks in advance! This is a 390 Motor I don't know if that changes things!
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
Yellow73
Re: I hope Some Of You Smart Guys Are Online
Post by Yellow73 »
The metal flap on mine is on the rear/bellhousing side. Unless mine are installed incorrectly,which might be possible since the engine was rebuilt prior to me owning it,but it works fine for all the years I've owned it. I edited this again my nubs are indeed facing up and the flaps are facing the rear/bellhousing side
ford4x4fun
Thanks! That is what I was looking for! I might get the motor in today yet!
US ARMY Retired
mrollings53
Post by mrollings53 »
Here's how mine are installed. With the open rubber side forward. Put the C6 where it needed to be, and everything bolts up together.
