FoPAR wrote:Truck is looking awesome Tyler! I've been so busy I've missed out on all your progress. Looks dam good man
Thank you Sir!! I'm looking forward to seeing YOUR progress too!
I went back and forth, looking at the pics of when you took it apart, and I have it now! Well, that settles that, I'm going to go ahead and separate that lower section to seal that seam. Thanks Tyler!tylerb43 wrote:What you've heard is correct, Pat. That seem can look pretty decent from the outside, but packed full of scale rust down in there. I changed the lower sections, as the upper section is part of the inner box. I'm going to skim through this, let me know if it doesn't make sense.67nukeford wrote:Tyler, truck is looking great! I'm considering having to the the same with my bed, splitting the bedsides. I"ve hear horror stories about that seam running down the length of the bed, corrosion-wise . How much of a pain was it to get that upper section of the bedside off? Are you going to weld in the long seam, or just seal it?
Again, wonderful work, man!
Once I had both lowers separated, I welded 12 threaded studs to the new lower, and drill corresponding holes in the existing upper. I then coated the flange on the lower with 3M 8115 panel bond. Then (with help) I installed the lower panel to the upper, with washers and nuts on the studs from inside the bed, this squeezed the flanges together, filled the entire seam with the panel bond. After 48 hours, I removed the nuts, cut off the studs, and button welded the holes. - see pic below. the hole on the left is welded, one on right just had it's stud cut off.
So the seam is fully sealed from the inside, and welded at the "buttons" down the seam, and obviously fully welded at each end.
You got it Pat! Glad I could help, (or confuse, whatever the case may be, ha!)67nukeford wrote: I went back and forth, looking at the pics of when you took it apart, and I have it now! Well, that settles that, I'm going to go ahead and separate that lower section to seal that seam. Thanks Tyler!
Coupe5oh wrote:I dig the wood floor, it's gonna look awesome. The truck is really coming together. Is the Eastwoods stuff on the cab floor similar to dynamat? I'd like to maybe layer something over the fatmat I've got on mine but don't know if its necessary. Whatever carpet I get should have jute padding anyway.
That lightning is sweet too. Ive always wanted one, a friend of mine had a white one that I should've bought about 5 yrs ago. It was a really nice, fun to drive.
