Anyone have a factory 1969 Ford truck service manual? Volume One specifically? I need to have something looked up, because I am missing that volume from my set. Please PM me if you can help.
Thank you,
Art
owner of several 67-72 as well as 73-79 Ford trucks
Wanted: Parts for my 1930 Dodge coupe project - the DD model was built in 1930 and 1931
I am looking to see how Ford recommends to adjust the axle bearing endplay on the 68/69 1/2 ton trucks with a Dana rear axle. They have tapered roller bearings and use a thrust spacer between the two axles.
Hello Art: There is way too info for me to type here, but I can give you some general info. When assembled, ready for the road,these axles must have an overall axle shaft end play of 0.001 to 0.010 ,measured at the right axle shaft flange. The procedure for checking the clearance is nearly a full page & my typing skills are not that good. Also there is a different procedure between using the original parts & new parts. Have A Great Ford Day!
68 Ford Stepside wrote:Hello Art: There is way too info for me to type here, but I can give you some general info. When assembled, ready for the road,these axles must have an overall axle shaft end play of 0.001 to 0.010 ,measured at the right axle shaft flange. The procedure for checking the clearance is nearly a full page & my typing skills are not that good. Also there is a different procedure between using the original parts & new parts. Have A Great Ford Day!
Thank you for the fast reply. I hear you on the typing thing. My fingernails always have dirt under them
I'll PM you my telephone number.
Thank you again,
Art
Hello Art, Calling you is not an option at this time. I am suffering too much stress & pain from my ongoing fight against intestine & liver cancer. Have A Great Ford Day!
Last edited by 68 Ford Stepside on Wed Mar 27, 2013 10:26 am, edited 1 time in total.
A friend is currently battling brain cancer and I thought he was a goner... He continued to be positive and the outcome so far has surprised everyone, including the doctors...
Keep fighting it. Don't give up.
