DOUBLE CHECK YOUR HOOD LATCH!
max_alberta
Post by max_alberta »
I went out today to try out my brand new rebuilt carb... hit the freeway, got up to 50 MPH, and the hood flew open and slammed into the drip rail! Braked hard, pulled over to the shoulder... slammed hood, got in truck, drove home.
Damage? The hood is ruined. Both hinges are broken. The drip rail is fine. Could have been a lot worse. I may chain the new one shut!
SecondCamperSpecial
Re: DOUBLE CHECK YOUR HOOD LATCH!
Post by SecondCamperSpecial »
I feel your Pain. Did same thing last fall. My hood is fixable but then it is time to paint the truck.
1968 F250 Camper Special 390
1964 Galaxie hardtop 352
1967 Cougar project
1993 F350 Crew cab 5.8
1988 Bronco 5.8 C6
1966 Mustang fast back project
New 1962 Falcon Gasser project
toddspeed
Post by toddspeed »
Lucky it didn't take out the windshield and the roof...I had a carbon fiber hood fly open at 120mph at Mid Ohio last year - it destroyed the hood, hinges, windshield, roof, and a pillars.
So why are the bump hoods flying open?
Todd in Atlanta
1970 F100 Ranger born the same month/year as me - 360 C6 2WD, P/S, LWB
You! Yes You! Please put your location in your profile - it helps us help you when it comes to parts, pricing, and advice.
Nitekruizer
Post by Nitekruizer »
Glad to hear it didn't do any more damage. A buddy had this happen with his '70 Impala. He'd just finished doing some work on the engine. We hit the highway, got up to 60-65 mph when the hood flew open. :eek: It basically bent the hood in half, but surprisingly, didn't do any other damage.
I'm not concerned too much about originality with my projects so, as a preventative measure and because I like the look, both projects got hood pins. :)
390 FE IN A "BUMP" / 383 WEDGE IN A 2 DOOR C-BODY / 351W IN A FULL-SIZE MERCURY / 194 CHEVY 6 IN A DUECE / 2.4 DOHC CHRYSLER IN A PLASTIC BUBBLE (Driver)
SoCalExile
Post by SoCalExile »
This reason is my theory on why my truck came with extra hood badges on rear, the wrong year F-O-R-D letters on the hood, and hood pins.
Whateverman
Post by Whateverman »
:lol: had that happen in the truck my bro and i built out of leftover crap from my truck ,a $50 302 core,a c4 with a 2500rpm stall converter and some go fast junk leftover from discarded projects...we were "testing" the 302 and the hood flew open at exactly 30 mph after a pretty hard launch- tore the rusty rad support apart.taco'd the fenders and MANGLED the inner fenders.. :roll: . :lol:
Dan
Post by Dan »
Seems to be a trend here! In another post I did "The wreck of the ol' 67" the hood flew open on that one as well on the freeway after a second front clip had been installed. So he chained it shut with a lock after that.
max_alberta
I haven't looked back at my post... I figured out why it flew open. Some previous owner removed and didn't replace the secondary hood latch. I've got a "new" truck now... I can only imagine how scary it would have been in the '70 impala, that car has a hood the size of a sheet of plywood!
jp2005
Post by jp2005 »
Same here! Hood, hinges, and roof damage 50 mph. I take a bolt and welded a chain link to it and drilled a hole though my radiator support on the drivers side. Then I take a chain and looped it through the hood and pad locked it. Works great and keeps a**holes from stealing your battery and air cleaner.
