neutral saftey switch and back up lite switch
- danno
Where in H____ do you mount the safety switch and backup lite switch on a C-4 tranny. I changed my truck from standard to automatic and all I have left to do is put a safety switch and back up lite switch on and cant find wear to mount it or maybe I don't have the right switches, Its a 74 c-4 tranny and steering column with shifter on the column. Please Help
65 f-100 4wd short bed 360engine c-6 tranny
Re: neutral saftey switch and back up lite switch
Are you saying you have a '74 Column? The bump side NSS is located near the bottom of the column inside the cab.
- bluef250
Ford changed the safety switch location to be internal to the transmission sometime after 1972. Some using later model columns with early model transmissions have modified the column for a safety switch. Seems to me that you could hook up to the internal switch in the transmission. I have not seen any diagrams of the later model transmissions and where the switch is located.
I have several tilt columns to install and will cross this problem later.
- danno
Yes its a 74 column, I look all over for the NSS but I cant fine a place to mount the one I got for it, It looks like it mounts to the column but no screw holes or nothing like that. and back up lite switch hooks up with the NSS harness
