Wish I Could Figure It Out
68 Ford Stepside
Post by 68 Ford Stepside »
I was reading on the net how the 300 six is capable of 30 mpg running a carb.I sure wish I knew the secret. :)
Produced at the Cleveland Engine plant in Brook Park, Ohio from 1964 through 1996, the 240 and 300 Sixes are well known for their durability. Simple design and rugged construction continue to endear these engines to a number of Ford enthusiasts to this day. Many have run 300,000 to 600,000 miles (480,000 to 970,000 km) without any more service than standard oil changes.[citation needed] The engine has earned the monikers "bulletproof" and "indestructible" by many. There are numerous claims of those who have purposely sought out to destroy one through abusive use, and were unsuccessful in doing so.
One example of the engine's sturdy design is the fact that no timing chain or timing belt (both of which can break, causing unwanted downtime or even engine damage) is used. This generation of Ford Six was designed with long-wearing gears for that purpose instead. Very few modern engines use timing gears; belts and chains are by far more common.
Both the 240 and the 300, no matter the application, used a single barrel Carter YF carburetor until the introduction of Electronic Fuel Injection. With proper gearing, many F-trucks and Broncos are able to achieve over 30 mpg with these carburetors, when properly tuned. This was heavily used by Ford's advertising campaign (some television advertisements and written literature even claimed 30 mpg), since the V8 engines in these trucks rarely achieved over 14 mpg. Modern rebuilds are possible to reach 40 mpg in some cases.
The fuel economy of the 300 makes the engine a popular choice amongst truck enthusiasts that want both power and economy. The addition of performance parts (such as intake and exhaust manifolds with a four-barrel carburetor) place the engine power output near the same levels as the stock HO (high output) version of the optional 351 V8, with little or no change in economy. There are claims of 300s that have had the power output doubled, or even tripled, with less than a single mpg drop in fuel economy.
"Have A Great Ford Day"
hazelnut
Re: Wish I Could Figure It Out
Post by hazelnut »
Sounded like a good salesman for snake oil.
elgemcdlf
Post by elgemcdlf »
I don't think 30 mpg would be that difficult to achieve. I am talking highway mileage & not city. I have a '90 F150 4x4 Lariet SWB that does 22 on the open road if I hold to 55 mph. When I go above that mileage suffers greatly. Sometimes all the way down to 15. It was between 65 & 70 that got me 15 mpg. I would bet if I geared that truck a bit higher I could get close to 30 mpg at 55 mph. It is a fuelie with a 5 spd & has lockouts up front with a part time transfer case. I could see a 2wd version of this truck doing 30.
68 Ford Stepside
I did notice in the write-up that the 30 mpg was achieved using a Carter YF carb. Carter YF carbs are still being used in Australia today. In fact they can be purchased brand new. I think I will price one tomorrow.I would be elated just to get 20 mpg on the old flareside. :)
