I see no grease on your dist. cam....I can't really see the color of the point surface, but it should be gray & no pitting or transfer of metal..
If one side of your points has a high spot & the other side a low spot or the color is not gray..that could be excessive voltage or a faulty cond.
Replace the points & cond, lube the cam, set them at.016 & do the timing thing...The black inside your carb is showing your complaint.
When you replaced the acc. pump, did you pull the little orange check valve into your float bowl & then snip off the tip...
Also use your thumb nail to test your float if it is a black "plastic" material...These soak up fuel and become heavy, just nick it , if it is wet at your nick, replace it...if it is brass leave it alone, just set it..
The diaphram on the top of your carb in the rear is the choke unloader...they deteriorate, but are available & adjustable..
The way that the choke works: the spring in the bakelite cover will close the choke when you hit the throttle on a COLD engine, this will close the choke plate,,,,then as the engine starts-vacuum is supplied to that unloader & it will pull your choke open a predetermined amount & allow the engine to get some extra fuel until the spring in the choke housing warms up & opens the choke. NAPA should have this part
The adjustment for the float & the unloader should be included in your rebuild kit instruction's
also do a Sarge said, flat sand your pump cover, you need a good squirt of fuel,,,Agood spark at the right time & U should be OK......Donnie
Were your points worn out of spec...like closed/? I would get a set of "Standard" brand points...Or from a Ford dealer...not today
