1. Hole patched in floor
2. Power steering flushed and new fluid
3. Exhaust leak fixed
4. 1 axle seal replace
5. Wipers replaced
6. Windshield leak fixed
7. Plugs changed
8. Truck washed and waxed to protect paint
7. Engine cleaned
8. Master Cylinder replaced and all bleeder valves replaced
Currently Being Fixed:
Rear brake
Heat control valve
Brake warning light
The oil will be changed again before as its almost been 6 months.
Is there anything else I should check or replace before using the truck as a daily driver? Does anyone else daily their bumpside here? Thanks
