1967 F100 Resurrection - On The Road Again!
- pincheweddo
- pincheweddo
Re: 1967 F100 Resurrection
Looking good! What harmonic balancer did you choose? I like the looks of that one. And do you have a timing pointer yet?
- pincheweddo
The link to it is on my blog post. You can click on it and takes you right to it. It has a pulley assembly that is adjustable for your application. I have the pointer that was on the engine already, just haven't put it on yet.sargentrs wrote:Looking good! What harmonic balancer did you choose? I like the looks of that one. And do you have a timing pointer yet?
Duh! I went and read your updates but the thought never occurred to me to click on the pretty red hyperlink. Thanks!
- pincheweddo
Water leak has been located. They say you can't fix stupid, but I just did.
http://1967f100.blogspot.com/2013/09/35 ... esson.html
- pincheweddo
Made lots of Motor progress! Serp system is well on its way to be done.
http://1967f100.blogspot.com/2013/09/blog-post.html
Thanks Pinche! You just saved me ton of heartache with that bracket write up on your blog. I'll be doing the exact same thing when I get my engine. You're my hero!
- pincheweddo
Awesome! Glad it helped. Just remember its all easy but the bolt acquisition will drive you nuts.sargentrs wrote:Thanks Pinche! You just saved me ton of heartache with that bracket write up on your blog. I'll be doing the exact same thing when I get my engine. You're my hero!
- pincheweddo
Found headers that work for a 351w in a bump side! Sweetness...
http://1967f100.blogspot.com/2013/09/an ... erson.html
- pincheweddo
Re: 1967 F100 Resurrection - 351w Headers found!
Got more done today and the headers are installed.
http://1967f100.blogspot.com/2013/09/we ... urned.html
- Craigerf100
Looking good, nice headers. Would the long tube headers not fit with your 351?
What destributor you gonna run?
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
My Build: http://www.fordification.com/forum/view ... &sk=t&sd=a
- pincheweddo
Long tubes weren't what I was looking for. Plus they would probably hit the crossmember. I will eventually get a pertronix cause I have one on my tractor. Won't do anything too extravagant.Craigerf100 wrote:Looking good, nice headers. Would the long tube headers not fit with your 351?
- Craigerf100
i went electric distributor and i wont ever go back. i didn't the points eliminator kit. and it was better. but man oh man when i put a simple 2 wire electric distributor. the engine just pepped up. before it was running like an old dryer with some nuts and bolts tossed in.
after it tightened up, ran so smooth and clean. and it was a 40yr old original high mileage motor
so unless an EMP hits here im running full electric distributor.
im even running a after market distributor. a knock off of a mallory. it even has mallory part #s inside it.
got it for $60
got one for my truck for $80
got it for $60
- pincheweddo
That's good to know. I am planning on stock dist with pertronix kit, or a whole new pertronix dist. Buddy of mine claims not having electronic pick up on SB fords is silly.Craigerf100 wrote:i went electric distributor and i wont ever go back. i didn't the points eliminator kit. and it was better. but man oh man when i put a simple 2 wire electric distributor. the engine just pepped up. before it was running like an old dryer with some nuts and bolts tossed in.
got it for $60
