Truck Weight
Damon23
Truck Weight
Post by Damon23 »
I was looking over tech and it says that my truck weights roughly 3460 but the calculation does not give different motor's. Does anyone know the weights of the different motors? I'm trying to figure out if my truck and trailer will handle hauling the F100 to Daytona for the turkey run. It is a 18ft equipment trailer and a 2wd excursion so it should be fine.
70shortwide
Re: Truck Weight
Post by 70shortwide »
not sure what truck youve got, but my 2wd shortbed weighed in at roughly 3800 lbs. with an iron headed 460 stroker, c6 auto and stock suspension. I may have had an extra 50 lbs in the interior...FWIW
Damon23
Re: Truck Weight
Post by Damon23 »
Just a swb 2wd with a inline 6 and 4speed. Custom cab with no ac. I'm sure the figure I saw is close just didn't know the difference in weight between the motors.
sargentrs
Re: Truck Weight
Post by sargentrs »
My F100 LWB style side with a 302 and 3spd, with no options at all, weighed 4140# according to the scales at the dump. This was a consistent number every time I went over several years.
72customF
Re: Truck Weight
Post by 72customF »
My 72 short bed with 302 and c4 weighed in at 3,410 WITH me in it. So i'd say aout 3,200 lbs.
Mike- (72 SWB Chassis, 68 Ranger body, 69 Ranger grill) 72 302 bored 30 over, 69 351w heads light port work, Erson TQ20H cam, Weiand Stealth intake, Edelbrock 1406 carb, MSD 6T circle track ignition controller, C4 with transgo shift kit, Ford 9inch rear with Eaton Truetrac LSD. Much more in the works!
Image Image Image
FORDification
Site & Forum Admin
Site & Forum Admin
Re: Truck Weight
Post by FORDification »
The factory curb weight listings are for base model trucks with standard options, including gas/water/oil. Six-cylinder engines and manual transmissions were standard.
As for the various engine weights, use this chart:
