Help...Swappin' 16.5" wheels question
Gardener
Post by Gardener »
So here's what is up. I have a '72 F250 with the dreaded 16.5" wheel. (Boy those tires a hard to find, and at a price that won't bust the bank!) I want to replace them with standard 16" steel wheel so I can retain the original Dog Dish caps and look.
Will newer factory E250-350 Van Steelies fit? Called my local Ford Dealer to find out and got NOTHING. "We don't have info that far back"...WTF?
Anyway, I know the bolt pattern is right but not sure about the Hub Bore and stud size. Can anyone advise on this.
Thanks, Jon
Alstoyz
Re: Help...Swappin' 16.5" wheels question
Post by Alstoyz »
You should be fine... The holes for the hubs should be fine. As long as ur wheels are a 8 on 6.5 bolt pattern, ford, and they use acorn style lug nuts. (No washers) You may want to convert to a early-mid nineties 9/16" lug studs.?. I've done this a couple of times now... It's quite simple. :thup:
1970 F-100 SWB Tubbed
1971 F-350 4X4 (traded for 71 crewcab)
1971 F-250 Crew-Cab Dually
1972 F-100 SWB 4X4
1972 F-350 Crew-Cab 4X4 Dually
2001 F-350 Crew-Cab Short Bed 4X4 Dually
kg9aq
Post by kg9aq »
I have a set of 16" wheels on my 68 that came from a 1996 f250. I believe they went "metric" after '96?
'68 F250 Ranger
'99 F250 Super Duty Powerstroke Diesel
Kurt Combs
Post by Kurt Combs »
The hub bore does not matter, the 16" rims are lug-centric.
Kurt
1972 F-250
Art
Post by Art »
Kurt Combs wrote:The hub bore does not matter, the 16" rims are lug-centric.
As long as you are working with Ford rims, this is true.
Many GM and Dodge rims have a smaller bore that will not pass over the Ford axle hub.
owner of several 67-72 as well as 73-79 Ford trucks
Wanted: Parts for my 1930 Dodge coupe project - the DD model was built in 1930 and 1931
Like vintage drag racing? http://www.meltdowndrags.com
youngone
Post by youngone »
The only issue I ever had with 16 inch rims is sometimes the rims fit but don't turn because the disk brakes have a bolt to hold the slider for the callipers. If that is a issue you can use a allen wrench type bolt that hols the slider.
They always fit the rear of the truck just sometimes not the front. FWIW Good luck. :fr:
68_250
Post by 68_250 »
I pulled mine off of an 85 F250. THe original dog dishes fit just fine.
Russ Stanley
68 F250 ( ol' Grand Dad)
71 F100.( Old Blue)
65 Valiant Wagon (Gone but not forgotten)
2007 PowerStroke(The Golden Goose)
