Fuel line routing
jefflovesf250s
Fuel line routing
Post by jefflovesf250s »
All: Am upgrading my '66 brake system to a '67 dual chamber M/C and brass distribution block at the frame. Brass block and brake lines to front & back now installed, but I'm struggling with routing of the 5/16th fuel line thru the area.
Can some one post a photo of the brass distribution block area showing how the fuel line is routed?
I.e does it go behind the steering gear box in the "groove" in the frame boxing behind the gear housing or around the outside of the steering gear housing between it and the engine block?
If it goes thru the groove what route does it take at the brass block?
Thanks so much for the help (and photos).
sargentrs
Re: Fuel line routing
Post by sargentrs »
Here's a couple of pics I have on file. The line ran from under the cab, center of the frame rail, and then went under the distribution block, under the steering box (in the groove), up and over the crossmember and under the engine perch.
jefflovesf250s
sargentrs Hey, thanks ever so much for the photos. Helps a lot. This forum is awesome, full of so many helpful, cooperative ford folks. Jeff(JefflovesF250s)
