aftermarket steel replacement parts
- doughboy68
just got my new aftermarket core support and I have a question...are they ready to install or do I need to primer and paint prior to install??? I am leaving black so?????
- elgemcdlf
Re: aftermarket steel replacement parts
Paint it. That is just a coating to keep it from rusting while in stock. I don't remember what it is called.
- jimmy828
I had ask the same question when i purchased mine. From the advice from some on this site ,i decided to scuff,prime,scuff again, then paint. I used spray bombs. After all the work it took to change it out i was looking for a little more protection.
- chad67
The black is an electrostatic coating to prevent rust while on the shelf, but offers very little chemical or UV resistance. If left unfinished, it will turn chalky and the part will eventually start to rust through the coating. When I put on a new body part, I always paint the inside before I put it on, too. Leaving the inside with only the electrostatic coating is why a part with a good coat of paint on the outside will rust from the inside until the outside bubbles and cracks off like an egg shell.
1967 F100 SWB
- doughboy68
I thought it was something temp... I will get r done!! Thx for the input!!
- HIO Silver
I think it means Electro-Deposition Primer.elgemcdlf wrote:Paint it. That is just a coating to keep it from rusting while in stock. I don't remember what it is called.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
