Home done gauge cluster
mw2158
Post by mw2158 »
Just finished this, used an old metal insert, cut out the center replaced it with a piece of 16 gauge that I drilled for ebay gauges and for turn signal and hi beam indicators. Painted black then used "engine turned" stick on vinyl.
69Ford
Re: Home done gauge cluster
Post by 69Ford »
Awesome its always fun to make your own one a kind setup and have fun doing it to. Looks good.
Mancar1
Post by Mancar1 »
Good for U, looks great :thup:
Put em in and keep on Trucking :drive:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Amero
Post by Amero »
Looks nice!
ximy
Post by ximy »
Nice vintage look!
jimmy828
Post by jimmy828 »
good work :thup: . I want to build myself one but more focused on getting the darn truck running first.
