Home done gauge cluster
Just finished this, used an old metal insert, cut out the center replaced it with a piece of 16 gauge that I drilled for ebay gauges and for turn signal and hi beam indicators. Painted black then used "engine turned" stick on vinyl.
- 69Ford
Re: Home done gauge cluster
Awesome its always fun to make your own one a kind setup and have fun doing it to. Looks good.
- Mancar1
Good for U, looks great
Put em in and keep on Trucking
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Looks nice!
- ximy
Nice vintage look!
- jimmy828
good work
. I want to build myself one but more focused on getting the darn truck running first.
